Hi Jeff,
I certainly don't profess to be an expert on the subject of carburetion but I've learned so much in the last few months working on my 302 engine. As has been spelled out in this thread I am currently using an OS 2a also. I have it to the point where the engine runs almost flawlessly, from idle to full acceleration. I have the air bleed wide open and I believe I could open up the diameter of the port a little but I really don't want to alter this carb. I can use it as a test carb for other engines. I ran the engine for almost four hours over the 2 days at NAMES. It was getting quite warm and as it did I would have to richen up the needle one or two clicks to keep it fine tuned but it never faltered.
This engine has a bore of 1.00 and a stroke of .900. I can idle it down to 700 rpm and rev it just shy of 5000 rpm. There were fellows stopping by that had Walbros and other types of carbs on their engines and were amazed at the performance of this simple little air bleed carb. As I said and as some others have stated the problems I was encountering were not fuel related but rather ignition problems.
When I first built this engine I made a scale copy of an Autolite 2100 carb for it. This carb was pretty much the standard issue for Ford v-8 engines that used a 2 barrel carb. The one I made had a butterfly for the throttle plate with idle passages, a float etc. The biggest problem was getting the float and needle to operate in that small scale. I didn't have much luck.
Now that I have the engine running so well I wanted to remake the 2100 carb purely to add to the scale appearance of the engine so I took all of the dimensions from the O.S. carb and sat down at my drawing board and designed a new carb.
I had to figure out how to get the rotary throttle barrel into it but have the outside look somewhat realistic. I also had to figure out how to get the fuel from the inlet to the needle valve using the scale dimensions from the full sized carb. It took some extra drilling to get the passages into it and I then plugged them with small set screws in case I wanted to alter them in the future. I also wanted to add more detail to the carb to give it that scaled down appearance so I added the accelerator linkage and the automatic choke mechanism. The choke unit sits over top of the needle valve and kind of hides it. I must step back here and say that before I added all of the extra detail I tried the carb out on the engine. It ran almost as well as the OS carb. By that I mean it would still accelerate clean and would idle 'almost' as well as the OS. I had the airbleed wide open and it could use more air at idle just to clean it up a little. I think that the length of the bleed passage added some restriction to the air flow and that is why it was just a tick off of the OS.
You can see in the pictures the size of the main venturi bore and the barrel is about .04 smaller in diameter. This gives the barrel hole a diameter of about .160. My needle jet is drilled .036 diameter and I am using a sewing needle soldered into my valve body for mixture control. The diameter of the fuel passage from the fuel inlet to the needle valve is .063.
What does all of this mean? I have discovered that most of our carbs are way to big in the venturi department. For an engine having a 1.00 bore I would start out with a carb having a venturi no larger than .200 diameter. You can always go bigger.
The first 2 pictures are overall shots of the new carb with all of the window dressing on it. That's a dime sitting next to it. The next 2 pics show the bottom of the carb with a scale next to it to show the venturi size. The last 2 pictures show a closeup of the needle valve area and how I used a plug to fill the bore for the barrel. I keep it in place with a 2-56 countersunk screw.
You'll have to pardon the dust on the top of the carb as this was the top from the original carb and it's been sitting for quite some time.
