- Oct 1, 2010
- 1,404
- 431
malofix,
The traditional, "precise" way to mark up a workpiece is with a scriber. You can buy one or grind a sharp point on some other piece of hard metal. The idea is that you scratch a mark right into the metal you want to work. To help with this process, you dye the metal first with a "layout dye" (like "Dychem" here in the US, or use a "Sharpie" marker to put ink over the metal.
Obviously, the sharper and more concentrtic your scriber is the more precise your mark will be. When you are ready to cut metal, the more closely you follow the lines or points, the more precise your point will be. Many use magnifying glasses to get their cutters on target to the marks.
Backing up a step: Locating the marks is a large part of the battle, and you do what you can to do that well. Here is where you study a drawing well to determine where to measure FROM, and in some cases you have to plan a multiple-step process to get where you want with the end result. Here is also where you might use a flat surface (a Surface Plate, or a piece of plate glass, or any known-to-be-flat surface.
Your approach using a paper pattern introduces the chance or accumulating more error, although sometimes it might be necessary. For actual measurement, you should have multiple measuring tools and use them as necessary. The ruler (sometimes called a "scale") is useful directly, but in some cases you might use it to set a pair of dividers to a dimension that you then transfer to your part. If you're measuring over from an edge, you might use hermaphrodite calipers and use the built-in scriber. You also might be able to scratch a mark with regular calipers, but I don't like that approach as it might wear or bend the calipers. To transfer measurements, you need machinist square(s).
Here is where I ask you not to take offense. I like to encourage your efforts and boost your enthusiasm, but it seems you might be "getting the cart before the horse." It might be beneficial for you to study some of the YouTube videos available where you can see projects of all types being completed and where the things you have been asking are addressed in the course of those projects. There are also many good books out there that provide a good background. I realize that you may have some issues seeing videos or buying books from your location, but I think you might be able to get at least some of what you want.
I don't have many of the books myself, as YouTube has a lot to see for free: It has been worth some of my time to spend a few hours a week online as well as in the shop.
Some YouTubers I check, that you might find useful:
TubalCain, aka mrpete222, aka Lyle Peterson (American, not to be confused with the British Tubal Cain) He is a former High School shop Teacher who covers a lot of background and includes several model-engine-building videos.
Oxtoolco, aka Tom Lipton. He supervises a development laboratory for his day job, makes inventions and does jobs out of his professionally-equipped home workshop, and has authored some books on metal shop and hobby metal shop techniques. With a scientific background, he has made some videos about achieving ultimate precision and extreme precision in measurement.
(I'll leave the list at this point, as I'm sure others have their recommendations.)
--ShopShoe
--ShopShoe
