So, today the testing goes on. First step was to remove the sparkplug from the non firing cylinder and test it. Yes, it does spark when laying out on the starting table. Next step was to hook my air compressor with 60 psi pressure to a line plugged directly into the sparkplug hole. As I turn the flywheel, air comes out the exhaust pipe when the exhaust valve is open, or air comes out the carburetor when the intake valve is open, and when both valves are closed no air is escaping anywhere. That shows that the valves and the piston ring are not leaking air pressure. (Same test was administered to the cylinder which is firing.) Next step was to use my other airline with a check valve and balloon and plumb it directly into the sparkplug hole. As with the other cylinder, the balloon gradually gets blown up as the engine is turned over by an external power source. The displaced volume in each cylinder is less than 1 cubic inch, so the balloon does not blow up super fast. The intake valve on the cylinder being tested does not begin to open as soon as it should---instead of beginning to open at 15 degrees before top dead center it begins to open right at top dead center. I can adjust that particular cam if I have to. One of the first things I will do today is to get rid of the 12" long flexible rubber hose that reaches from the sparkplug adapter to the readout dial on my compression tester, so the gauge can be directly coupled to the sparkplug hole. If I still get no reading, I will look for a zero to 40 psi dial for the compression tester, which currently has a dial registering from zero to 300 psi.
