appears to be separationin degrees between intake and exhaust cam lobe centers. Also, the lobes lobes for the two cylinders appear to be identically in line, that is the intake/exhaust timing is identical for both cylinders.
Does your compression tester have a check valve? Many don't, and the dead volume of the tester itself messes up the compression ratio of small cylinders causing incorrect low readings.I changed out my 300 psi pressure gauge for a 60 psi pressure gauge. I got rid of the flex line. Still, no pressure showing up on my compression tester when I turn the engine over a number of times. I spoke to Andrew Whale in the U.K. about these results, but he said that he has had the same result show up when he tried to do a compression check on the small engines which he builds so successfully.
So were your cams near the correct position prior to setting them up with the rotary table? From everything that you have said before it seems to me that incorrect cam position is the most likely problem. You have not been able to get compression in the same cylinder but putting pressure in that cylinder with the air compressor does not find any obvious leaks and swapping ignition and fuel does not make any difference.It's been a long 10 minutes, but I think everything is happening in the correct sequence. As the piston closest to the flywheel is going down on the power stroke, the piston farthest from the flywheel is going down on the intake stroke. I'm going to assume that YES I have it right and start putting everything back together.
Hi Brian, If one cylinder is firing the the cams for the other cylinder should be exactly 180 degrees opposite in the direction of rotation check this out and you should have compression and a beautiful running engine to be proud of.JohnThe engine is back together and ready for another try. Everything has went according to plan. I went to a grandsons hockey game this morning and spent the afternoon doing a final reassembly. I even got a little paint on the larger flywheel, which was made from a pulley I had made a couple of years ago for something. Wish me luck.
Hi BrianSo----The engine is finished. This build has carried me thru January, February, and March. It started out as one carburetor feeding a single manifold that spanned between both cylinders. As the engine evolved, I couldn't get the single manifold spanning between both cylinders to seal properly, so the cylinders were fitted with one carburetor each and a single intake manifold each to get away from the sealing problem. Some confusion on my part lead to having to ask for some help when setting up the individual cams on the camshaft, and I feel that I have indeed learned something new. I never was able to come up with a 12 volt coil that had dual outputs, so I "borrowed" the 12 volt coil of my dual opposed cylinder engine because I know it works. I made a new style of gas tank based on one that Andrew Whale from the U.K. built, with glass ends and I like it very much.---I can now see at a glance if the engine has ran out of fuel or not. Only one problem remains, and that is that I can't get the damned engine to run!! I will continue pecking away at things until I have a runner, and then I will probably post the engine drawings for sale. Although this engine was base on Malcolm Stride's engine, the Jaguar, it has a different bore, different stroke, different ignition and different lubrication system. Thank you all, readers, for following the build.---Brian Rupnow--26-March--2024
