What, you have opticians that can grind a lens perimeter, opticians around here buy their lenses from one of three companies that own the industry? My optometrist that requires a 'dispensing optician' on staff, buys from the Zeiss lab in Vancouver, a 40 hour, non-stop drive away.Hello everyone
I also once had the problem that I needed round glass panes to my desired dimensions.
I wanted to turn a rectangular volt and ampere display into a round display to get a vintage design.
A friend of mine owns an optician's shop and he makes glasses.
He has a CNC grinding device where he can grind the shape of the glasses frame from the lens blanks.
I bought a small picture frame with a 2 mm thick glass pane.
He broke this pane of glass into four squares.
He then ground the round glasses from the squares to my desired diameter.
Just ask an optician's shop whether they can grind your round glass panes too.
Such a grinding process only takes a few minutes.
Unfortunately I don't have any pictures of the CNC grinding machine.
With the pictures I show you the way from the rectangular to the round volt display.
Dieter
