Nelson If you look at the very first post, I think that you will see that the engagement lever on my model is in the same place as the one on a full size saw. As I understand it, first you started the engine with the lever not engaged. Then you grabbed a handle on the parallelogram and lifted the saw blade so it was not touching the wood, then you engaged the lever and after the saw started moving you set it on the log so the weight of the mechanism would make the blade cut.---Brian
