mklotz said:
Aren't those different genders? :big:
Woke up several times last night thinking about one thing. (Okay...two things but we won't talk about that.)
The stud (aw gee...this is bad timing)...
You'll remember that it fell out when the solder softened from a later operation.
In, what I like to call wisdom (but you might call inevitability), I had bought extra material should a desire to duplicate a part (hee hee) overcome me.
So I have a hunk of 1 3/8" round by 1.2" brass that I bought to 'duplicate' the end sheets. If I were to 'follow the construction notes' I would cut this in half and be back at the same starting point as when I received the kit.
When I do that, I'll have two (less than) 0.6 pieces of brass that will get trimmed to 0.16. So what I'm thinking is...
Make the stud an integral part of the end sheet. That is...when I go to turn (face) the part down to .16...turn it down to the 'stud' and then thread it. No soldering necessary.
What do you think? It's waste brass anyway. The alternative is to use 45 silver solder for the stud and hope that I don't melt it when I solder the end sheet on with 56.
Another question...as I said, it's only 1.2" long (the stock material). That will make it an interesting exercise to bandsaw cut. Do you think I can hacksaw this? (You know me...and I won't take offense.) Or what about parting it? Too much? (If I did I'd part close to center and then break it off.)
Oh...and something else...tmuir (as well as others) have suggested using copper or brass tubing instead of the drain pipe. I'm not ready to give up on that. I'll probably take the (yes...I did get a spare) drain pipe and see if I can work it better than the last one. If I can...I'll go for it...if not...I'll..I'll...cry first and then think about it.
