- Feb 17, 2008
- 2,330
- 446
Nick, you are right. That is a separate issue from what I was talking about, but also applies. I just pulled up the Tiny drawing and checked to see what I had done on it. Without allowing for valve lash, I had 110 degrees of exhaust from start to finish. With a 0.005 allowance for lash it dropped to 105 and with 0.010 lash it dropped to 99 degrees. Those are cam degrees, so double those numbers for crankshaft degrees. It has a flat cam follower which is not affected by lash as much as a roller follower. I think it could use another few degrees added to open the exhaust a little earlier, but I don't think so enough to make a new cam.
Gail in NM
Gail in NM
