- Sep 2, 2011
- 1,396
- 384
for tapered pins something i discovered by accident is just the deflection of turning down a very small thin rod usually produces a slight taper. i just drill a regular hole and then drive the tapered rod into place usually the pin starts in really easy then starts getting tight before i start pecking it to "drive" it on in. then cut off the excess on both ends. sometimes i use lock tight on them as well but usually the taper in the regular hole is more than enough to keep them in place. i guess this is probably considered as "crude" but it works great for me.
