Black Widow V8 difficulty?
Ah, but it is easy to prove that one designed an engine when it is presented HERE as an original. It has a date and it has thousands of witnesses. The onley thing is, is it truely an original design? That is, could it have been copied from someone elses design? In the 60s, remember, there were two fellows who came up with a design for the first laser. The guy with the NAPKIN design from a restaurant won the lawsuit. The two guys partnered up in the end. A-OK.
That doesn't always work, there are patent trolls out there that are listed on the stock exchanges, if you want to learn a bit more that, watch the video I ran across last evening, 'Why the U.S. Patent System is literally SCAM! | The Patent Scam | FD Finance' The patent office is allowing the patent of ideas, someone could make an unbelievable vague patent that covers the use of the those lasers and sue anyone that uses them, the lawyers said it could cost you three years and $3M to win against the trolls!
Hello all
Don’t mean to jump in here. If this engine the guy is claiming to have the rights to. It would’ve had to had a patent on it correct. Ok so let’s say it did have one and depending how it was classified the patent would be good for 20 years or 30 years. But the deal is if it was covered and then sold the patent is no longer any good the patent does not go to the next owner nor do any rights to anything. The engine all the drawings all of it would no longer be covered by any patent. As per the United States patent regulations. Also if you are the original owner of the patent and you change the drawings later in life those changes are not covered under the original patent design. As per the United States patent office rules. You cannot simply buy the patent or rights to something and claim you own the rights to it because the patent does not follow the item. And it is the same way with trademarks once it is sold the trademarks are over. I believe this is how this works from what I am told by a parent attorney that I happen to know very well.
Tom
Definitely a copyright issue. In the U.K. you would initially have to write a cease and desist letter stating how you claim the copyright. Presumably something along the lines of having an original drawing with copyright statement and date would be reasonable, or a receipt for purchase from the original IP owner.
You can only sue if you can demonstrate a financial loss due to the copyright infringement. E.g. Loss of sales of a drawing.
It’s quite straightforward if someone has the copyright on a drawing, or if they produce castings and sell them. Less clear if they don’t produce castings for their engine.
You can make castings from a copyright drawing for your own use.
Have you been able to do anything with this project yet?
I just found my set of the Solidworks drawings of the Black Widow. A college instructor did them and did them poorly with no rev. numbers. About 700 megabytes of drawings and miscellaneous files.
Anyone interested in taking on a work of monumental effort?
Hi Mike,
Send me a PM so I can give you my email address to discuss what we're looking at.
gbritnell
I would think that anyone redrawing this would need to have a set of castings infront of them to make sure that whatever they draw can be got out of the castings. Also if it is like most sets of drawings then only the machined details are dimensioned so you would need to have the castings to confirm the rest of the drawn shapes are correct.
Ideally they would also build it to prove the drawings.
At least that is the way I have done it when redrawing casting kits where the revised drawings will be published as well as ones just for my own use.
I think it would be easier to make a correct 3D model, then 3D print the patterns with shrinkage allowance, and then make new castings.
Otherwise you will not really know what you will get, like the proverbial box of chocolates.
Gentlemen,
I have zipped the Black Widow files into a 333-megabyte lump. I will send it to anyone who wants to try the work. I need your email addresses so I can send the file via Sendthisfile.com. You will get an email with a download link. So pm me with your address.
I have. A question. I downloaded all the files and went through every folder and subfolder. There was a lot of repetition of drawings so I printed out one of each that seemed to be a separate part. It states on the Martin website that the castings are sold with I believe 22 pages of drawings. Before I spend untold hours going through and making drawings, what exactly is Martin using for drawings?
From what I got from Martin when I purchased the castings has some differences from what I got from Mike Remus. Like you I went through all the files, there were some I couldn’t open because of the format or related to Solid Works which I don’t have. After looking at the whole pile of drawings from both parties I have made the conclusion I need to just start with the castings and work from there. I don’t want waste $2K I paid for the castings to be ruined because I followed the drawings.
I also downloaded the files. The folder named "engine list" contains essentially what Gary is providing with the casting set. I agree, there is much duplication.
I purchased the castings and drawings from Gary last year. The plans have a number of issues. There are missing components, missing dimensions and dimensions that are wrong. It's a challenge to use the plans with the castings. The drawings are a helpful starting place, but you will need to modify them so the part can be machined out of the casting.
I started my modeling with the crankshaft and worked out. In my opinion the block casting won't support the crankshaft as the drawn. I started my block drawing from the plans but then had to make modifications to both drawings to accommodate the block casting.
Another example is the water pump. The plans are represent parts that are completely different than the castings supplied. It's likely most builders won't use the castings.
There are a so many builder decisions that need to be made, its likely no 2 BW engines will be exactly the same.
I'm currently building my 2nd BW. The previous one was over 10 years ago. Simply put, with both engines I find the plans are lacking when it comes to consistent measurements with several dimensions that don't match the block casting. Some dimensions also do not remain consistent from plan page to page specifically for the cam and crank. What has resulted is constant altering of dimensions to 'make it fit'.
Sorry, I have no idea.
Only a suggestion as I have no skin in this game but if anybody is sitting on raw castings, do not do anything!
I went through this exact thing when building the Peewee V4. Lots of information missing. I sat down and modeled the entire engine in 3D CAD. Then I had to draw all the missing parts. Last was correcting errors.
By the time I finished the drawings were so different that they could not be used to build an engine if the machining was started. Had to start with a clean set of castings.
So smart money is to wait and let George and others sort out what's good, what needs to be added, and what needs to be fixed. When complete everybody get what they need. Also send a copy to the person selling the castings so future builders get a good set. I sent mine to Dirk Tollanaar when finished.
I am one of the original owners of the black widow V8 kits! I owned one of the original 10 castings as well as 2 of the second run previous to the foundry burning down that Mike Rehmus referenced. Although I am in possession of Don's (The college professor) entire 600+mb of drawings as well as many of Dwights and Kens hand drawings, I would like to say that this project is a seat of the pants project that Dwight himself would tell you was mostly in his head before Don was hired to try and sort out and put together a plans package! The truth is That the plans that are being sold with the kits is the attempt of Dwight to supply a basis to start the engine that were randomly picked poorly by Dwight and he put duplicates as well as incorrect copies as Don's class rendered them.
I would like to throw my 2 cents in on the blowhard known in this post only as "Castings" If I decide to make my own Ketchup or Catsup, Heinz cant claim ownership! Dwight and Ken may have been sparked by the Challenger but they improved on it and went their own route to produce it.
I would also like to mention, as Mike Rehmus can attest to, that the only person that can take claim to the Don drawings since his unfortunate passing is NOT "Castings" or even Dwight or Ken for that matter, the person that funded Don to produce those drawings to the tune of thousands of dollars was a gentleman that both Mike and I know (whos name I wont mention in this post), that has successfully built and is still finishing the last 4 of 15 complete RUNNING black widows!!
Once again just my thoughts on this!!
