Ok how about a 1/4 scale supercharged nitro burning model top fuel 1967 era hemi engine Operating 14-71 supercharger more commonly called a “blower. “ no plans available. Since these are “ dry block” no water passages needed. But probably could use a couple water passages for bench running about 30$ a gallon for nitro but it could run on alcohol I YHINK there may be a plastic model available if you look far enough my son has a real one so basic measurements would be available if necessary as well as pictures if you really wanted a challenge he has a full 3 disc centrifugal clutch and suitable bell housing with Lenco 2 speed transmission. The engine has complete “ bird catcher fuel injection
I'm looking for plans for a next build that would be comparable in complexity to the Inline Six, 270 Offy, Knucklehead, Merlin, and radials I've built, but I'm not having much luck. I own a set of castings and the documentation that came with them for the Black Widow V8, but I'd rather build an engine from billet. I've spent the last month or so working on SolidWorks models for the components of a 1/3 scale Ford Hi-PO 289 V-8, but all I have to work from are undimensioned photos from old shop manuals and 60's era hotrod books. Although I'm making progress, its a tough slog, and I can see my enthusiasm dulling before I get to the point where I can actually start making chips. I have access to the German 'visible -V8' plastic model of the Ford V-8 sold by Amazon, but it's turned out to be a disappointment and only useful for top level sanity checks. Does anyone have any suggestions? - Terry
Hey Terry, This might be a little late but there is a book called "Ford Small Block Engine Parts Interchange" The last few pages are dimensioned drawings of the Ford small block, heads, crank.I'm looking for plans for a next build that would be comparable in complexity to the Inline Six, 270 Offy, Knucklehead, Merlin, and radials I've built, but I'm not having much luck. I own a set of castings and the documentation that came with them for the Black Widow V8, but I'd rather build an engine from billet. I've spent the last month or so working on SolidWorks models for the components of a 1/3 scale Ford Hi-PO 289 V-8, but all I have to work from are undimensioned photos from old shop manuals and 60's era hotrod books. Although I'm making progress, its a tough slog, and I can see my enthusiasm dulling before I get to the point where I can actually start making chips. I have access to the German 'visible -V8' plastic model of the Ford V-8 sold by Amazon, but it's turned out to be a disappointment and only useful for top level sanity checks. Does anyone have any suggestions? - Terry
I used them when I modified two Ford 289's into a V12 configuration (full size)..... (Yes it runs)
Brent
PICTURES?
Here's some youtube vid's showing it. I tried to build a little demon but I guess I don't have the skills to make all those little parts. I had several ford v8's around so I used as many ford parts as possible so I gave this a shot. 3 year build. Maybe I'll dust off that little demon and see where it goes. It might be fun to build a scale engine of this v12. Hmmm?
Sorry, Don't mean to hijack the thread.
Brent
I second a BR-2 Radial
Intricate and complex
Or the Bristol Hercules sleeve valve engine
Your drawing prices are more than fair to my mind. Very professional, too.I sell my drawings for what I consider a reasonable fee given the hours spent creating them. You also have to realize that my drawings are quite complex so the average machinist might have difficulty building a model from them.
