- Jan 19, 2010
- 1,193
- 41
Have you ever heard of a black powder engine that runs?
Me neither. I have seen attempts on tv, but no success at all.
So, I have an idea that just might work. It involves a semi-automatic pistol/rifle, and a connecting rod and flywheel, with some sort of "Valve" mechanism to pull the trigger at the right time.
If you mount a connecting rod wrist pin pivot on the sliding part of the rifle I.E. an SKS or AK47, and connect it to a crank with the same throw as half the slide, and then pull the trigger it will rotate the flywheel, then time the trigger pull with a valve gear of some kind.
This should work. Right?
I dont know if I will ever be able to try it though.
Bullets get expensive, this would not be a cheap engine to run.
kel
kel
