Ramoye
Gordon,I made new arms and panels. It has much better compression but I still cannot get it to run on it's own. It fires every stroke but not enough to keep it going. Then the braze on the crank broke and I just got that back together yesterday and decided to try moving the cylinder to get a longer compression stroke and a shorter intake stroke. It is closer to running but there is still something not quite right. I slotted the hole on the intake port and that may be my problem. So far I have remade just about every part but the base and the side panels.
If you decide to remake the arms and front panel let me know and I will send you my revised as built drawings.
Gordon
Had a good day today. The engine kicked over a few times on its own. It ran, with electric motor assist, more consistent than ever before. Cylinder got very hot. Switched to 1 7/16 links on both ends, and adjusted the piston rod lengths so that both pistons are nearly even with the ends of the cylinder. I had to play around some with the timing. I now have 15 hours on the new cylinder. I will run it some more tomorrow and see if it develops more power. How things going on your end? Ray
