- Jan 4, 2011
- 1,417
- 384
BTW. I did a theoretical compression calculation from the operating volumes in my CAD drawing and I figure the compression of the engine is only 3.2:1
I might be wrong on that. But if I'm right it's going to be pretty iffy for the engine to run. Also it doesn't leave any room for leaks anywhere.
Let me know if I made a mistake.
You should be able to measure that with a pressure gauge in the spark plug hole while cranking it. Theoretically it should measure about 45lbs. Too low to be reliable IMHO.
Thank you for your input. I found at least two places where the drawings are at least incomplete. On page 81 it shows the connecting rod hole on a 2 7/16 radius line which is pretty much worthless without a location on that radius. I think that I guessed wrong and have been trying to compensate ever since with different connecting rod c/c and different link arm c/c. As I built it the pistons hit each other. Also the intake valve stem interferes with the RH pivot arm and the arm must be reworked to provide clearance.
I redrew the engine also except that I only do 2D which does not show running interference. I may have to bite the bullet and learn 3D but I am comfortable in 2D after using it for about 20 years.
I think that your take on low compression ratio and the engine only runs if everything is exactly right. That would explain the extended run in times most folks experience.
At this point I am torn between just setting it on the shelf at least for a while and keep on trying after spending all this time on it.
Gordon
