Is this the single cylinder engine i.e. not the opposing piston type?
I built one of these years ago and it works fine.
Mate of mine knocked up some castings for the barrel, head, uprights and conrod, the rest is machined.
Very touchy on the fuel needle so once set I leave it be.
Also plug can get fowled up easily so I up-ed the voltage on the coil to 12v and works fine now.
Fuel is just unleaded petrol with around 5% oil. Have tried methanol as well with castor, seems much the same.
This next bit is a mystery to me....perhaps the inlet could be a poppet valve but the Exhaust????
There should be a video of my engine on youtube somewhere, see if I can find it and put in a link.
Due to the design of the intake and exhaust valves there is a very short part of the stroke between exhaust and intake. Both valves are atmospheric operated, that is no mechanical opening, only exhaust pressure and intake vacuum opens the valve
