........then look here! http://toys.shop.ebay.com/i.html?_n...ries&_odkw=carburetor+.10&_osacat=2562&bkBtn= Dave.
Brian Rupnow said:Holy Cow!!! Information overload. Its not so much a matter of not knowing where to buy a carburetor, as not knowing what carburetor to buy. Jeez---There are a hundred different carbs available, and they are all different. ...
cfellows said:You got that right, Brian. Very confusing. And most of them are designed to run on Nitro, not gasoline or Coleman Fuel. And they are designed for high speed, 2 stroke engines. Would they even work on a Webster???
Longboy, what does the .15 signify on all these carburetors? Also, any idea what the venturi bore on them would be?
Edit... I see the first Traxxas has a bore of 6mm, almost 1/4". Do you think there is anything smaller?
Chuck
Like Charlie said the fractional number of the carb refers to engine size. Its working fine on My Webster. It only uses about 1/3 of throttle travel from idle to 3000 RPM. A good experiment would be to get some Ace Hardware Denatured Alky or some methanol from the drag strip and see if this carb would needle out enough to use this fuel. As for smaller carbs the answer is a definite maby. Smaller carbs would likly be part of the crankcase casting with an intergrated needle. I wouldn't get lost on their venturi diameters but on something like your low RPM Henry Ford this 6mm Traxxis would be more ideal with greater range of throttle movement if it is a smaller size than my .15 carb. Maby ask Gbritnell for his insight!cfellows said:You got that right, Brian. Very confusing. And most of them are designed to run on Nitro, not gasoline or Coleman Fuel. And they are designed for high speed, 2 stroke engines. Would they even work on a Webster???
Chuck
I epoxied the exhaust pipe and valve guides to valve bock. Exhaust seal has not failed in the heated environment.Brian Rupnow said:.............when the engine Gods whispered to me that "Hey---the valve guide is loctited into that housing!!!" Silver soldering it would have really messed up my day, do I loctited the exhaust pipe in place too...........
IronHorse said:I was at Pinnacle Hobby store in Markham last week and I saw they sell all kinds of R/C carbs starting at $20. I am sure there are some R/C hobby stores up in your area.
IronHorse
Brian Rupnow said:Thanks to everyone who offered advice and help on this issue.---Brian
Brian Rupnow said:Does anybody know---Does the fuel tank outlet have to set higher than the Traxxas carb for a gravity flow to the carburetor, or will the engine vacuum draw the fuel up to the carburetor. I'm figuring out a fuel tank, and would like to know.----Brian
