steamin
- Aug 25, 2009
- 233
- 141
Good Evening, The plans for the La France call for a lot of items to be made from flat stock, especially the brake levers, brackets and supports. From my perspective this would be kind of boring to look at. The four attached pictures shows the basic technique that I have applied to achieve a 3-D effect and helps to represent a cast piece.
Picture #1 shows a flat piece of 0.030" thick brass sheet that has been shaped for one of the two front foot brake arms. There are 3 collars attached to the flat brass via 2-56 FHMS. The one at the left will be for the link to the next brake lever. The one in the center will be pinned via a taper pin to a shaft that links both arms together. The one to the right is the mounting hole for the foot bar. The curved piece is 0.062" diameter brass rod that is being shaped to fit in between the right and center collar.
Picture #2 shows the 0.062" diameter brass rods in place.
Picture #3 shows the assembly all soldered together and ready for clean up. I use a Eutectic 157 solder and liquid flux. This particular solder and flux is great for dis semiliar metals. In this case I was able to just unscrew the 2-56 screws from the soldered assembly. Sometimes a little solder will flow into the tapped hole area and I have to drill them out. I use flat head screws so there is less head contact with the main assembly therefore less clean up work to do.
Picture #4 shows the cleaned up arm in place on the front of the La France. The shaft in the center collar will be flush with the outside surface and pinned with a 00 taper pin at a later date. I like to use taper pins instead of set screws. It makes for a cleaner installation and they can be hidden under the paint if they are not to be removed.
Thank you for you interest and support
![IMG_0004_1.jpg IMG_0004_1.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/7/7465-IMG-0004-1.jpg)
![IMG_0005_1.jpg IMG_0005_1.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/7/7466-IMG-0005-1.jpg)
![IMG_0007.jpg IMG_0007.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/7/7467-IMG-0007.jpg)
![IMG_0008.jpg IMG_0008.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/7/7468-IMG-0008.jpg)
