My spark plug wire terminations and boots showed up today so I got them installed.
Great looking engine, Steve. I bet this thing will really sound off.
What is the coil you are using?
Chuck Kuhn
I made my own cutters. I made a 30, 45, and 60 degree cutter. After this pic was taken I knocked down the back side of the teeth with the dremel tool.
I couldn't wait any longer
Those are really cool cutters!
By dremel grinding the back edges, is that because the cutters were heat treat hardened?
I see the knurl there on the edge, are these cutters intended for hand turning vs. powered in an electric drill or something?
Those radial slots to make the teeth relief, is that using an end mill?
I assume by the 30, 45, 60 deg set you are ending up with a nice thin 45 valve seat contact area & the other 2 sizes are for relief?. Do you have a trick that regulates depth because this must be pretty small amount of material to remove?
Hey Steve,
I like your solution to the valve seat cutter problem, I will keep that in mind for future reference. Are you planning to bring your straight 8 to names ?
Art
Mawitö;210426 said:haha who can?, those cutters looks great, i though it would be more complicated to do with more angles, is that the same principle as in D bits cutters?
I could bring it if you would like to see it. Would you like to see it assembled or would you rather see it with the head, oil pan, and manifolds off?
do you have pictures of it on HMEM
[I found it!
http://www.homemodelenginemachinist.com/f31/straight-8-a-7451/ /QUOTE]
Thanks for the posting ,it's to bad that 90% of the pics are gone
[I found it!
They weren't gone, the links were broken. I fixed them. Try again.
Steve,
As much as I'd like to see it together I think I'd rather see it apart. Now that you have the links fixed I'll have to go back through the build thread and see the pictures.
Art
