Steve I have built 6 compressor engine and had to use 10 in flywheel that weight 10 lb to get them to run good.
They just won't run with a light flywheel.
Wayne
Aren't you afraid that the cast flywheel will come apart when you rev them up?
Wayne
Well I have a starter thingy made and the throttle is temped on there. I'm a little worried about the compression. When I tried to turn it over the battery drill had a hard time and started smoking. I moved over to the "good" drill and oh my god! The motor was jumping all over the place. I had no doubt the rings would be fine and now I know the valves are fine too. The only problem I see now is if I can hold the throttle open with one hand and crank the engine over with the other. My next post might be in the "mistakes, blunders, and boo boos" or the "machining with disabilities" sections. But only until the broken wrist heals.
I'm soaking the fuel tank with gas right now and will give it a final flush and see if it will start in just a few hours.
Hi Steve,
Would love to your engine started,running and roaring away.
Gus Teng.
Pressure cast flywheel that expired on a 3-1/2 horse Techumseh years ago when I was a kid.
Engine modified ;D
I can still hear how sudden it stopped! My finger was on the carb throttle until the expanded cooling shroud knocked my fingers away from the carb.
Learned a few things that day. A sand cast scares me even to this day.
Later in life started blowing up steel things drag racing.
Sounds like a lesson well learned. However, as small as some of the cars are today, no reason you cant adapt a flywheel off something like a 3 cyl Chevy sprint or the like...
Done for the day! Just tore the chuck off my drill.
Need a new plan!
i think you need to get rid of the ugly flywheel and machine and anodize a custom one! you could try using a model airplane 12v starter. all you need is a cone in the front of the engine in place of a prop spinner.
wow. it has some serious compression obviously! i think maybe a compression relase and a heavy flywheel might help it. i know that its pretty easy to pull start a 250- 350cc honda generator engine.
Most small single cylinder engines have decompression lobes on the camshaft it opens the exhaust valve just slightly just before tdc and when it starts it is disabled by centrifugal force. As I said before in case you missed my post Steve. Should be easy for a man of your talent
Well i read through all this and you sir are a legend! I want to see and hear this thing run, so heres a bit of a tip that i hope helps you out: You can pull the starter you bought apart and make it run backwards, basically set the body of it 180 degrees out should do the trick. We get a few home repairs we have to un-do like that at work (motorbike mechanic by trade) they usually have locating lugs on them to make sure you put them together right, you can just grind them off or do what my customers do and force it on regardless... :/
Anyway, give it a shot, depends on the starter but if its the usual permanent magnet type, 180 degrees out should reverse the rotation. If its the other type a little rewiring will reverse the direction.
I also watched through the attached a video showing the construction of the valves. You used "soft" solder
Frank
