That's what I had guessed at, thank you.
Hi Chuck,
To my way of thinking this last incarnation looks to be on the right track as the throttle should not adversely effect the fuel air ratio as it opens and closes, whereas the earlier design with the outboard throttle would greatly alter the mixture becoming very rich when it is closed, just my 2.5 cents (plus GST). Keep up the good work.
Terry
Hi Chuck,
I've been following your fuel mixer adventures. Interesting and it sure runs well on your pipe fitting engine.
Just to make sure I understand, the only path for the bleed air is directly into the fuel inlet/needle valve tube where it mixes with the fuel?
Also, when you are running with the main air control pretty well open, does blocking the bleed hole cause any change in engine operation?
Chuck
Chuck--what's the latest carburetor news? I know you will come up with something incredible, and I don't want to build a carb which you have already "moved on" from because you have come up with something better. I thought the one you posted plans for seemed to work very good on your Henry Ford engine, but almost as soon as I modelled it, you were moving on to something else. I do have a model airplane carb I can use on my engine for its initial start up (That's assuming there is an initial start-up.) I am rapidly running out of things to make for my engine. About all I have to do now is put a keyway in the crankshaft and get those two arms in that the guy in Alabama is making for me.
This lowered the compression ratio to probably around 4 to 1. It settled the engine right down, making it a lot less feisty!
