;D ;D
Well done Rich, that certainly got your burner working a lot better.
Suggestion if I may: -
Rather than go head long in to changing everything/anything on my suggestions list, it would certainly pay you to run it as is a few times and make carefull observations of exactly what is happening.
I noticed several things whilst watching your video, some of which could have one or more reasons/solutions.
E.G. shortly after starting the engine speed dropped quite a bit... WHY?
Was this due to lack of steam?... I did notice a pressure drop... if so how do you solve this?
and what are ALL the implications of any changes made?
Or was this due to Back pressure in the exhaust? (possibly due to water build up in the oil separator partially blocking the exhaust inlet from the engine).
If it was this then what are the probable causes for this? and what is the best way to resolve the problem?... indeed, can it be solved in this instance, without major surgery, or are there conflicting reasons for it happening? ( I can think of at least one of these).
Or was it due to lubrication (or the lack of it) somewhere?
I also observed that the top cover on the oil separator was actually lifting at regular intervals, but did not actually observe any clean steam exiting from the top of the funnel.
What do you feel is causing this? and how can it be best solved?... again, I can think of/see possible reasons for this not being totally solvable with the setup you currently have.
I am not for one minute suggesting that things cannot be improved Rich (my suggestions list follows standard steam practice) but this is an ideal time to really analyse the dynamic operation of your plant and then think about the possible cause and effect of certain characteristics... followed by remedial action/s if deemed worthwhile.
Spend some time with it, take carefull notes of your observations, then use my list as a guide and try to pick out which one/s could be the cause/solution then try altering one thing at a time... run it again and compare notes between results.
Some items on my list are inter related... I won't tell you which at the moment, see if you can work out which ones they are... and why? :
:'( :big: :big: and I will tell you if you are correct. ;D ;D
I think you will learn a great deal more by doing it this way rather than changing many things at once.
Keep up the great work.
Best regards.
Sandy. ;D ;D
