Hi
After cleaning up the vertical connector is silver soldered on. Sorry no photo of this, must have forgot ??? ??? ??? Then a good clean up and polish. The spindle has a 10BA thread put on. 10BA goes nicely onto 1/16 rod. Finally I made a little hand wheel. I've used this method before and was successful with it so I have adopted the same method here.
Center drill a bit of 5/16 brass round and drill tapping size for 10BA.
Then tap 10BA
Move to the mill and rotary table in the vertical position and cut 6 flutes with a small cutter.
Turn the rotary table to the horizontal position and centre drill 6 positions.
Then drill with a small drill. Drill as deep as the drill will allow.
Back in the lathe part off.
I managed to get 4 hand wheels out of it. 3 will go in stock for the future.
The hand wheel is screwed on with a bit of lock tite and a 10BA nut.
Rich
Then tap 10BA
Rich
