And here is PART 2... some of the more obscure things...
OIL TRAP/ SEPARATOR
This component is responsible for more confusion than almost any other as far as model steam engines are concerned.
Amongst model steam enthusiasts it is, more often than not, referred to as a CONDENSER and most people would know exactly what this component was. However, in the true sense, a condenser is the last thing it should be called, since condensing is not its function.
The purpose for its inclusion in our model steam plant is to help extract the waste STEAM OIL from the EXHAUST steam, whilst at the same time NOT CONDENSING the steam itself.
The STEAM OIL is not, as sometime suggested, in a true vapour form but takes the form of small globules of HOT and very FLUID steam oil suspended in, and carried within, the high velocity steam entering the engine.
Some of this suspended oil will impact upon the surfaces of the cylinder walls, piston and other engine components where it forms a fairly even layer of oil, thus lubricating the engine.
Some of this suspended oil will pass straight through the engine and leave through the exhaust port having done no work at all.
Some of the oil that did get onto the cylinder walls and piston surfaces will also leave via the exhaust ports, but some will always remain within the engine. This forms a protective layer when the engine cools after use and helps prevent any corrosion.
So, it is the temperature of the steam that reduces the VISCOSITY of the STEAM OIL such that it is very, very fluid but it is the VELOCITY of the steam flow that carries it in the form of small globules.
The oil is not a true vapour, since that would require very much higher temperatures to achieve.
HOW then do you remove the oil?
Simple answer is… slow down the steam flow velocity and the oil will fall out of suspension.
This is exactly what the OIL TRAP/SEPARATOR is designed to do.
Exhaust steam (carrying some waste oil) will enter the OIL TRAP/SEPARATOR at a velocity governed by the exhaust pressure and the bore of the connecting pipe work.
On entering the main chamber of the OIL TRAP/SEPARATOR, via a smallish bore entry pipe, the exhaust steam is faced with a relatively HUGE space, having a much larger cross section than the entry pipe, GREAT says the steam, I can expand, and I doing so its velocity will fall, as will it’s temperature and pressure.
If the entry steam is also directed towards the sides of the expansion chamber the oil, contained in the expanding steam, will have a large surface on which to collect, so aiding the separation.
The expanding steam, now free of oil, will exit the expansion chamber through the larger bore outlet pipe and can be directed to atmosphere via any chosen route.
In Rich’s case it is passed up through the inside of the funnel to aid the burner drafting of the boiler.
NOW for the tricky bit… Whilst the steam is expanding and slowing down in the expansion chamber it gives up some of it’s LATENT heat to the walls of the chamber… if this heat exchange is too high then the steam WILL CONDENSE back in to water.
The trick is to have a large enough chamber; with a large enough surface area to slow down the steam and collect the oil that drops from suspension, but without making the chamber so large that it can take too much heat from the steam.
To this end the cooling MASS of the OIL TRAP/SEPARATOR, and any heat absorbing surfaces it is in direct contact with, must be given close attention.
The best balance is to arrange for the temperature of the chamber walls to be just a shade lower than that of the steam, which will also aid the oil separation by way of increasing its viscosity a little, but still remain above the condensation temperature of water steam.
By allowing the outside walls of the chamber to be in contact with the surrounding atmosphere then this will conduct some heat away from the chamber walls…but this should not be too excessive or the steam will condense on contact.
SORRY RICH, but on this one you have got it a TAD WRONG… you have bolted yours down to a very large heat sink.
I would suggest that you introduce an insulation layer between the OIL TRAP/SEPARATOR and the BASE PLATE.
The steam leaving the OILTRAP/SEPARATOR should, in an ideal world, take the shortest possible route to atmosphere.
In practical terms, as in your case Rich, a certain length of pipe work is necessary.
Now, the exhaust steam is at very low pressure and also is very close to condensing temperature so the need to maintain this temperature until it reaches the atmosphere is paramount, otherwise it will condense in the pipe and create un- wanted issues… hence the suggestion to LAG it… furthermore, if the pipe is mounted in a continually rising format, then any condensate that does form, especially whilst the set up is warming up, then it will pass back into the expansion chamber under gravity.
Finally Rich, you expressed some concern over the amount of condensate collected in the OIL TRAP/SEPARATOR even though you only made a short run… Well, think about the MASS of the engine, it’s standard and the base on which it is mounted, compared to the relatively small amount of HEAT available in the small amount of steam contained in the cylinder. When your engine is cold (first starting) most of this HEAT will be extracted by conduction into the MASS of the engine (resulting in condensate inside the cylinder) and will continue to do so until the engine MASS reaches steam temperature… this could take some time… especially if you also consider the HEAT loss away from the engine MASS through its large surface area being in contact with the surrounding air.
Ok Rich, and Guy’s, that will do for now… Rich has come a very long way in such a short time and has learnt a great deal on his journey… there are a good few lessons to be learnt from this latest endeavour and I am sure he will make the most of his experiences with it.
Best regards to all.
And remember, no one knows all the answers, some of us may have more experience in certain areas but never the less can still learn new things, and there is always something to learn from everything we do.
SandyC. ;D ;D ;D
