;D
Hi Guy's,
Rich,
In general, for short or long term storage, I would always EMPTY a copper boiler, preferably whilst it was still hot, and then warm it very gently, with the filler cap OFF, to ensure it was thoroughly dry inside, I would then leave it to stand, unheated, until it cooled down to normal ambient room temperature... after which I would firmly fit the filler cap to seal the boiler.
It should then be stored in a WARM, DRY, and well ventilated, location.
Ideally, for long term storage, the air within the boiler should be replaced with an oxygen free gas, say 'ARGON', or even 'HELIUM', since this will eliminate any possibility of OXIDATION, however, for small model boilers, the small amount of oxygen content would not warrant this.
Completely filling the boiler with water, as suggested by Bob, is fine for shorter periods of storage, and is the method used by many MODEL LOCOMOTIVE/TRACTION ENGINE owners for storage between steamings... the only thing I would add would be to ENSURE the boiler cannot freeze whilst FULL of water.
As for VALUATION Rich... That is a very tough question...
Apart from direct material costs,
Do you include the HOURS taken to actually build it?
If so, then at what Hourly rate? (skilled work is not cheap).
What about SENTIMENTAL value?, and how do you/or can you quantify it's MONETARY value?
I am not convinced that an insurance company would pay much heed to the latter three of the above. They would be more likely to look for the commercial price of the NEAREST EQUIVALENT(not always so easy with a ONE OFF custom built unit) and perhaps add on a small TOKEN AMOUNT for them and call that the INSURED VALUE.
If any subsequent claim were to be made, they would then make a DOWNWARD adjustment, in thier favour, to take into account DEPRECIATION... as is thier WAY.
Keep happy.
Best regards.
Sandy. ;D 8) 8)
