dsquire
- Mar 18, 2008
- 980
- 15
Hi All
First, This is not about the contents of the photo but about the size.
Second, This post was composed with MS Word Pad in Times New Roman 12pt.
Third, I used Firefox as my browser while making the screen capture and also making this post. It will be interesting to look at all 3 posts in IE8.
Lately (actually for quite a while) photos seem to be all over the place in size. Some posts I just refuse to go any further when I have to wait for the 2048x1536 photos to load. To make matters worse sometimes there are a dozen or more photos. Now the only way to see what is in the photo is to go to the bottom of the page and use the slider to move the photo over then page up to the top, look, go to the bottom again, repeat over and over again getting more frustrated all the time.
If all that isn't bad enough, on the 3 main hobby machining boards that I spend my time MadModder, HMEM and MEM I can put up exactly the same post and it will come out different on each of them. I have made a screen capture. The original size is 1024 x 768. I have made copies of it using Photo Re-sizer in 800 x 600 and 700 x 525. I am going to put a copy of each size in this document using photo-bucket and also using the "attachment" process.
I will also put a link to the post on each board so that you can compare one against the other and see the difference. Your comments are welcomed and appreciated but please load all 3 posts using the links below so that you can compare one against the other before commenting. Hopefully the end result will be that we can all read the posts without wearing out the page down key and the slider at the bottom of the post.
Cheers![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Don
Comparison Links
MadModder
http://madmodder.net/index.php/topic,7559.msg81024.html#msg81024
Model Engine Maker
http://www.modelenginemaker.com/index.php/topic,607.msg5448.html#msg5448
Home Model Engine Machinist
http://www.homemodelenginemachinist.com/f29/3-board-photo-comparison-18768/#post193975
Photo 1 700 x 575
Photo 2 800 x 600
Photo 3 1024 x 768
Photo 1 700 x 575
Photo 2 800 x 600
Photo 3 1024 x 768
Don
Comparison Links
MadModder
Model Engine Maker
Photo 1 700 x 575
![Image700x525.jpg](https://proxy.imagearchive.com/b5f/b5f763468885e4d0cfc9e7e5909a4df3.jpg)
Photo 2 800 x 600
![Image800x600.jpg](https://proxy.imagearchive.com/bca/bca8afe89b6da7602bde6b5a0b3d1f6a.jpg)
Photo 3 1024 x 768
![Image1024x768.jpg](https://proxy.imagearchive.com/e7f/e7f2452df64bf5dff788b8d9548ea318.jpg)
Photo 1 700 x 575
Photo 2 800 x 600
Photo 3 1024 x 768
![Image700x525.jpg Image700x525.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/14/14178-Image700x525.jpg)
![Image800x600.jpg Image800x600.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/14/14179-Image800x600.jpg)
![Image1024x768.jpg Image1024x768.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/14/14180-Image1024x768.jpg)
