Don't know if I need one but I came across the plans for a rotary table here and in following Arnond"s build I decided to start one of my own. I am a real newby when it comes to machining as I have only had my mill and lathe for a few months. I decided to build the table mainly to gain experience on both machines and thought this project would challenge me, and it has to some degree. This type of stuff seems to come natural. I have made many mistakes on each part but one thing about machining you can a lot of times dig your way out, rebuild the part, or modify it at a later date to suite your needs.
I have used the plans as a reference, adapted what I had on hand, and added my own touch so to speak.
Here is the base. I started with an 8" wide by 1/2" thick piece of flat stock and cut pieces from it with the plasma cutter. I then milled the peices down so they were the same and even, and then welded everything together.
I wanted to use the T nuts and bolts I made for my vice to hold down the RT instead of the clamping kit. I also wanted to be able to mount it away from the column as far as possible if I should need it to work on a large piece. So I welded on clamping tabs to serve this purpose. I also welded the tops first so they would warp up just a bit.
I used a face mill? to mill all the parts up to now but even with the biggest fly cutter I had I would have had to take two passes to cover the top. So I chucked it up in the 4 jaw on the lathe and faced it off. My first major mistake, I grabbed the carriage feed instead of the cross feed and you see my mistake but it will be covered by the table and will not affect the operation of the RT. I might add I got to use my boring head for the first time to bore the hole for the bearing cup.
