That's great you got a refund, but with all the re-work it's going to take, that free table may still turn out to be pretty expensive in time.
But just in case it's not something you already know Wonk, if you try to use those division plates on another table, just be sure it also has the same worm and worm wheel ratio that your Vevor table has. 40-1 plates as an example could be used on something like a 90-1 table. But your actual division tables for whatever ratio that next R/T has would be useless unless you do the math. Even then, some divisions may not be possible.
Given the extremely poor build quality of that table I'm not sure I'd trust the hole count or even accuracy of there placement in those plates unless I double checked them first. Inaccuracy's in the actual hole placement are still divided by the worm - worm wheel ratio, so even an inaccurately done plate could be used to used to machine second generation plates that would be much more accurate. It just depends on what your using the R/T for and the actual level of accuracy you might need of course.
