If the addendum and dedendum are not right you can end up with rubbing in the inside of the worm wheel, (outside diameter of worm) and you might still have backlash on the tooth flank at the same time. Because the worm is touching the root diameter of the wormwheel the center distance cannot be adjusted any better. Then the only way to avoid high friction is to back off the excenter and accept the extra backlash.
If you have gaps on both tooth tips wormwheel and worm, then the eccentric bushing can be used to adjust until the tooth flanks touch, without rubbing.
