Builder01
- Nov 2, 2017
- 49
- 35
Hi Bazmak,
Yes, in order to cut left hand threads, traditionally you cut from the head stock to the tail stock. So, the chuck turns in the normal direction, but the tool moves from left to right, away from the chuck. As you say, you have to reverse the direction of the lead screw.
The pins in the nut for the Super, are 3/16" in diameter, 1/8" long. The reach rod fork can be "sprung" such that it will not come off the pins. It does not need to be any fancier than that. I believe I pressed the pins into the nut block, along with a drop of Loctite. The nut should be made of bronze, not brass. Bronze will wear much better.
Attached is a photo of some of the small boring bars I have. They are made from solid HSS tool blank. These take a bit of time to make. The one in the front, with the red layout dye, is the one I cut the internal thread for the nut. The round piece of brass is my "proof" or test nut, to see if I could make the nut. You can just see into the nut that the thread is left handed, you can also see where the two entry points are for the thread.
To cut the thread for the nut, you start with the tool inside the nut and cut on the way out, toward the tail stock. A diual indicator is handy to know where your reference points are. You do not want any distractions while cutting the nut. As you get towards the end, you can only test the screw in the nut after a pass is made on each thread. So, a single pass, involves two cuts, then test fit the screw. By making the screw first, you will get the idea.
I made the screw first. I measured the thread using the three wire method, as obviously, I did not have a test nut! The pitch diameter for the double lead thread, is the same as a single lead. There are thread pitch diameter calculators on the web and will also suggest what diameter wires to use. I used to do it the old fashioned way, but the online calculator is so much easier. If you get to this point, I can post the numbers if you are interested.
As for posting my own thread, I probably will not. Don't have enough time, although I do have a few friends on a mailing list that I occasionally send updates on my locomotive build. If you have questions about your build, I will be happy to post a few photos or comments as time permits.
David
David
