- Dec 12, 2012
- 2,220
- 1,288
Just the passageways and valve gear to do.Normal practice is to fit
studs and nuts approx 15 each side.More realistic but ugly so decided
my favourites the hex sock sets.In order to maintain location when the fixings and cover plate are removed i fitted 2 no recessed csk screws to secure the
steam chest. The 9 screws down the long sides co thru and fix to the cyl
while the 4 end ones are drilled and tapped to the chest only to avoid
clashing with the steam passages.The result is eaqually spaced fixings
as seen on top of the cover but when removed the chest stays put to
adjust the valves..Only one miss drilled hole which i plugged.Now to finis
h the valves and tidy up everything
