Very nice looking reverse set-up Bazmak. Looks a fair bit larger than the one I just did.---Brian
Thanks Brian,hats off to Stephenson to think it up.
Do a search for Keith Appleton. He has done a heap of videos that explain exactly what to do.Thanks David,just showing the extend of my ignorance.I am struggling at the moment to understand how to set the slide valves.I am waiting for some taper pins to arrive to pin any parts that require removal at times.I have pinned
the reversing arm to the weighshaft with a roll pin.The arm is vertical with the
reverser at midpoint.Can i now taper pin the the lifting arm at 90o and horizontal ? Can you ease me thru the valve setting and what i should and should not be doing. Regards barry
If you google Don L Ashton all you get is rubbish about MormonsI've mentioned my old friend before but Don L Ashton has written and published extensively and has a web site.
Of course, Don is also a world authority on things like tugboats and full size steam locomotives .
Don writes from time to time on Model Engineering Clearing House forum.
Also is an accomplished musician and composed and arranged saxophone music.
Great man and will go out of his way to help.
N
