Pistons and rings.
Pistons seem fairly straightforward, .002 smaller than the bore, ring grooves, and a pocket for the wrist pin. But that pocket wasn't so easy.
It's drawn as a rectangle, about .440" deep at the bottom of a .5" deep bore. The corners of the rectangle are rounded looks to be .063 radius.
But an 1/8" end mill doesn't really have the reach to do that, and you can't see down in the bore while you are milling. I figured how far I could move from center, X and Y, for the outside of the 1/8" end mill to cut the correct dimension. It felt awkward, and not being able to see what was going on was hard, but it worked out. I had to extend the end mill in the end mill holder to reach bottom. I don't have anything longer.
I'm pretty sure it was Rustkollector who said he put an oil ring on these pistons, and that seemed like a good idea, so I re-spaced the grooves,
to accommodate a third, wider ring. The compression rings are nominally .045" so I ground the back end of a parting tool to .045" and made
compression ring grooves. The oil rings are .063 wide with a tapered groove .010" deep and .035" wide at the bottom. A 1/16" parting tool worked for those grooves.
The needle in the second picture is about .035". Form tool for oil ring grooves.
I had a mandrel from a previous build that was bigger than this one, so I could modify it to work here. The rings were brought to just over
width on the mandrel, and holes drilled in the oil rings. I used a #70 drill (.028"), and made 6 equally spaced holes. (Trimble says he broke off a #75 drill so only 1/8" stuck out of the chuck and made 8 holes) I didn't have to break off the drill, it went far enough in to the chuck. I used a sensitive feed drill chuck so I could feed it with finger pressure. Got through 30 holes without breaking the drill.
(I only need two oil rings and 4 compression rings, but I made some spares)
Out of space for now.
Thanks for looking.
Doug
