Piston rings
To build these rings I did not follow the Trimble method because in previous experiences I had a lot of waste , after heating.
I wanted to try the method without heating of which I have seen videos on Youtube and I have read some explanations.
I used Nodular cast iron or Ductile cast iron (EN-GJS-400-15) ,the difference between traditional gray iron and ductile iron is the shape of the graphite. While cast iron has small flakes of graphite, ductile iron contains spherical graphite nodules.
The graphite spheres give it more resistance and elasticity than traditional gray iron which in my opinion is more suitable for making rings.
First step
Starting from a cast iron rod , I turned the OD leaving a 1 mm of stock allowance , the same for the ID
First step
