Heat Treating Aluminum Alloy
GreenTwin
Staff member
Global Moderator
MidSouth, USA
Normally aluminum alloy 356 is used for castings, and this heat treating process is based upon this metal.
Temperatures and such may vary if you use a different aluminum alloy.
There is some variation in the recommendations for temperatures and times to be used for heat treating aluminum.
These are the values that I use.
It should be noted that some casting folks pull their hot castings out of the sand and immediately quench them in water.
They claim this is all the heat treating they need in order to get a harder and cleaner machining aluminum.
I would recommend trying this first, and if this produces the desired additional hardness, then there is no need to apply the complete heat treating process.
T4 Solution Treatment:
There is a "T4" treatment called "solution treatment", and it consists of elevating the aluminum casting to just below its melting point, and holding it at that temperature for 8 hours.
I have read that some use a shorter period of time, but the white papers say that the solid solution process does not begin until after 6 hours, and thus the 8 hour requirement.
I use 1,000 F for 8 hours for aluminum 356 alloy, followed by an immediate cold water quench.
This temperature must be digitally controlled very carefully, since you are close to the melting point of the aluminum.
Some recommend a hot water quench immediately after this 8 hour period, but I use cold water, and have not had any measurable distortion due to using cold water.
A T4 treatment produces noticeably harder aluminum.
T6 Precipitation Hardening:
If you want the best strength and hardness, then use a second step, which is called "precipitation hardening", and this takes you to a "T6" level.
This step is easy, and can be done by heating the casting to about 400 F for perhaps 4 hours.
No water quench is required after precipitation hardening.
Other's may use different time durations and temperatures, but settings these have worked for me.
I was using raw 356 aluminum castings, and while they machined and drilled ok, they tended to load up the cutting tool, drill bit, saw blade, etc., and were what many including my self called "gummy aluminum castings", ie: not heat treated.
When I used the approximate T6 heat treating method, the aluminum seemed harder, appeared to machine more cleanly, and there was basically no more tool loading.
Interesting. Thanks for description. I always assumed 6061 & 356 were quite different compositionally & doing a T4 or T6 treatment to 356 was not going to get it to the same properties for those reasons, despite following the heat/quench recipe. But I guess 'different' is a relative term when you compare. Both are very high in aluminum % with trace other alloys (as important as they must be). But of note, 356 has significantly higher silicon % (6.5-7.5%) vs (0.4-0.8%) for 356.
So what happens if you throw 6061-T6 into the pot & cast it? Obviously you don't get native 6061-T6 but is it appreciably similar (or worse) to 356 or are there more obvious reasons why people don't tend to do this?
https://www.makeitfrom.com/compare/...61-Aluminum/A356.0-SG70B-A13560-Cast-Aluminum
I don't know much about aluminum alloys, other than some are good for extrusion work, and some are designed for casting work.
Here is an article about 356 and 6061 aluminum.
The article says 356 can be used in lieu of 6061, but does not really shed any light on why.
356 is structural grade aluminum that can be cast pressure-tight.
Pressure tightness is important for things like engine blocks that have water passages, etc.
Sometimes microporosity in aluminum castings can cause them to leak.
There is a way to treat them to get them watertight, but I forget exactly how.
Best to cast them watertight in the first place.
https://www.diecasting-mould.com/ne...osition-properties-uses-a356-aluminum-vs-6061
Here is an article by Reynolds Metal Co. about heat treating aluminum.
Page 15 discusses heat-treatable vs non-heat-treatable alloys of aluminum.
Table 3 towards the end lists the heat treatment of 356 aluminum to T6 as follows:
12 hours at 995 F, not to exceed (+ -) 10 F variation in the oven, hot water quench,
followed by 3-5 hours at 310 F, no quench.
  • Reynolds_Aluminum_Heat_Treating.pdf
    1.8 MB
