Corrosion pedia explains it all to do with ph, etc.
https://www.corrosionpedia.com/definition/407/distilled-waterK2
Just thinking out loud. Shouldn’t the coolant be coming from the top of the radiator to the engine ?? As is, the coolant is only circulating in the bottom portion of the radiator.Reporting Back on the Cylinder block de-rusting.
The engine is back together and I am using Prestone 50/50 premixed coolant and I am sure the corrosion issue has been dealt with. I have a few other issues I need to work on before I can go for longer runs. In the photo below I have indicated an oil leak. This is where the oil pump meets the timing case. There is a gasket between the oil pump and the oil pump cover and no leak occurred there. I am not sure why I didn't use a gasket also at the timing cover. Easy fix.
I did have some air bubbles at the coolant pump, this is a little aquarium 12V pump. I put both the inlet and outlet of the radiator at the bottom, then had a hard time filling it with coolant and getting the air out. I will turn it on its side and pull coolant from the bottom and return to the top.
I was surprised how quickly the coolant got hot and how hot the radiator got. I thought I could get away without a fan, now I am planning to add a 12 Volt fan blowing through the radiator. It would be interesting to put a few thermal sensors on the engine.
The distributor worked a dream. Should there be a grounding lug on the head for a current return from the spark plugs? I have the ground lug located on the base and the current needs to run across several part interfaces.
OK, back to it. I have a few changes to make to the engine test bed.
ALL motor manufacturers have basically the same chemistry of corrosion inhibitors (as I was taught by the LLC chemist!), as that is dictated by the common (cheap) metals used. (30+) Years ago, the exception was Norway - I can't remember their particular environmental reason for a different coolant corrosion package, but in the 1990s they changed to accept what the rest of Europe uses. I guess "chemistry" in Japan and USA - and all other countries - are the same?I went to the automotive parts store and there were 6 different types of antifreeze available specific to different auto manufacturers. In my tank cooled engines like Water Wetter. I have had a piece of 12L14 soaking in it for over a year without any sign of rust.
Jeff
Try wrapping some aluminum foil around the pump controller this is a sure way to tell if it’s EMI causing the problemK2,
Find my latest configuration of the cooling system in the last post of this page:
https://www.homemodelenginemachinis...ngine-based-on-westburys-wallaby.33191/page-5
The little aquarium pump works great and provides good flow, and the clear tubing allows one to see all is good. There is one exception--when the engine is running!!! The problem I have now is the "DC brushless" aquarium pump quits running when the spark plugs are firing. I posit that the ignition system is producing EMI (electromagnetic interference) that is messing with the DC brushless controller in the little pump. Uggg, if it is not one thing it is another.
With the radiator/cooler oriented the way I have it, flow in to the top and out the bottom of the cooler and in at the bottom of the engine, I get good coolant flow. The fan on the cooler really helps and I am getting rid of a lot of heat. Amazing how much heat this little 30cc engine generates.
This is just an engine test stand and not the final engine mount. I guess I could try a "brushed" motor pump, or design up an engine driven pump.
