Black Widow V8 difficulty?
Ah, but it is easy to prove that one designed an engine when it is presented HERE as an original. It has a date and it has thousands of witnesses. The onley thing is, is it truely an original design? That is, could it have been copied from someone elses design? In the 60s, remember, there were two fellows who came up with a design for the first laser. The guy with the NAPKIN design from a restaurant won the lawsuit. The two guys partnered up in the end. A-OK.
That doesn't always work, there are patent trolls out there that are listed on the stock exchanges, if you want to learn a bit more that, watch the video I ran across last evening, 'Why the U.S. Patent System is literally SCAM! | The Patent Scam | FD Finance' The patent office is allowing the patent of ideas, someone could make an unbelievable vague patent that covers the use of the those lasers and sue anyone that uses them, the lawyers said it could cost you three years and $3M to win against the trolls!
Hello all
Don’t mean to jump in here. If this engine the guy is claiming to have the rights to. It would’ve had to had a patent on it correct. Ok so let’s say it did have one and depending how it was classified the patent would be good for 20 years or 30 years. But the deal is if it was covered and then sold the patent is no longer any good the patent does not go to the next owner nor do any rights to anything. The engine all the drawings all of it would no longer be covered by any patent. As per the United States patent regulations. Also if you are the original owner of the patent and you change the drawings later in life those changes are not covered under the original patent design. As per the United States patent office rules. You cannot simply buy the patent or rights to something and claim you own the rights to it because the patent does not follow the item. And it is the same way with trademarks once it is sold the trademarks are over. I believe this is how this works from what I am told by a parent attorney that I happen to know very well.
Tom
Definitely a copyright issue. In the U.K. you would initially have to write a cease and desist letter stating how you claim the copyright. Presumably something along the lines of having an original drawing with copyright statement and date would be reasonable, or a receipt for purchase from the original IP owner.
You can only sue if you can demonstrate a financial loss due to the copyright infringement. E.g. Loss of sales of a drawing.
It’s quite straightforward if someone has the copyright on a drawing, or if they produce castings and sell them. Less clear if they don’t produce castings for their engine.
You can make castings from a copyright drawing for your own use.
