Roger B
This discussion isn’t really relevant to Ray’s engine as it is a four stroke but is interesting never the less. The conventional port controlled two stroke is a very simple concept but the inlet (transfer) port and the exhaust port have to be adjacent and open at the same time. It also tended to leave a volume of hot, burnt gas in the cylinder. Various port designs were developed to direct the inlet gas up into the cylinder so it purged the burnt gas and did not escape directly via the exhaust ports, which is wasteful, especially if fuel is lost this way.
To overcome some of these problems two main approaches have been used, firstly induction via ports that are open around BDC and exhaust via valves in the cylinder head. This ensures a good purging of the cylinder and allows separate control of the exhaust valve timing. Lloyd’s engine is based on this concept:
https://www.homemodelenginemachinis...diesel-56cc-2-stroke-will-it-ever-work.31110/
The other option is an opposed piston two stroke where one piston opens the inlet ports and the other opens the exhaust ports. This has the initial benefit that the inlet and exhaust are at the opposite ends of the (rather long) cylinder. It is then possible by playing with the design to open and close the ports at different times. If the engine has two crankshafts like the Fairbanks Morse that you showed or the Junkers Jumo the angle of the exhaust crankshaft can be advanced to open and close the exhaust earlier. This short article refers:
https://achatespower.com/crank-phasing-and-the-impact-on-engine-efficiency/
If the engine has a single crankshaft and side pull rods, the same mechanical design as Ray’s engine, a similar timing can be arranged by having a longer stroke for the exhaust piston than for the inlet piston. Maybe someone good at CAD animation could show this, but very basically the exhaust piston moves further than the inlet piston for the same rotation angle of the crankshaft. The set up has the added advantage that the heavier top piston assembly moves less than the lighter bottom piston and conrod and helps the balancing. This is the basis of the Junkers CLM I am building. The 65mm bore version has an inlet piston stroke of 90mm and an exhaust piston stroke of 120mm. The 85mm bore engine has strokes of 96 and 144mm.
