I recreated your alignment, Minh Thanh, using a 1/4" gauge pin for the vertical edge.
I drew a vertical line in paint. Then I thought I'm not sure if the end of the gauge pin is really 90 degrees to the vertical - gauge pins are accurate for diameter, not squareness. Because this piston isn't really big, none of my squares or 1-2-3 blocks or anything I have that I'm sure is square will fit in there and let me see the two holes. It's probably "close enough".
