It's hard to describe how messed up I was.
Let me show you:
There's a raised area on the shaft side of the that piece you made into a counterweight, in the red oval. It's .031 thick. There's a rim on the bearing that's also .031 thick (on the right). So I thought that's where that bearing went. If you don't look closely, the diameters match. The bearing is 0.500" diameter except for that lip.
The end views of that piece match. You posted the view looking at the shaft from the far side, let me post the view looking down the shaft at that piece.
We see the 0.313 is the shaft seen end on. That 0.500 circle, (.031 tall) is a mystery, though. Again, I thought it was that optional bearing, but that's 0.563" diameter. The lack of hidden lines in the side view wipes that out, too. It's just a raised area on the crankshaft side of that piece.
And I was looking at the crankpin grease cup on sheet 13 of the drawing to go in the top hole of that piece, where you have a threaded rod. I don't even see where that comes from. I mean, did you change dimensions on whatever that drives?
