CFLBob
In your video I seem to see the engine looks like it has no compression or very little compression ,Or am I wrong !?
my engine :
Question does your spark plug have a spark under compression try closing the spark gap to say .015 gap and try again.
That seems reasonable...as long as your bottom pic shows the exhaust cam just starting to open AND that this pic is taken at the END of the POWER stroke (in other words, about a half of a turn of the flywheel after ignition TDC. That part is important.).
IF that is the case, I would pull your valve block off and check the compression by holding your finger over the hole in the side of the engine frame.
You are now entering the "Twilight Zone".---Leaking valves----This is the part that separates the men from the boys Bob. I almost suffered from a Conniption fit with my first two i.c. engines, the Webster and the Kerzel Hit and miss engine because of leaking valves.
probably not the case, but your points cam - the flat doesnt seem as cut down as much as mine? and my points which my pic doesnt represent it but mine seem to be touching more flatly or symetricly or some other way of saying the contacts are flatly and fully engaged and the cam isnt influincing them in the least when its on the flat. that said i probably cut the flat further than i should have.
i have another question and im sure it was already addressed by others in this thread, but im going to ask anyway. i have no experience with the electronic ignition box you are using (ive only dealt with pertronix on tractors). does it still require a condensor or capacitor? or is it built into the kit?
bob, it also just occured to me, i have a webex account at work and a web cam that i can bring home on the weekend or after work. if it would help i can do a webex and let you study my engine and move it arround and zoom in on anything you want to see. or at least as much as the rinky dink web cam can do. if you are intersted let me know and ill try to bring all that home tommorow. including the engine.
