George_Race
- Jul 28, 2010
- 125
- 2
I have been encouraged since my first little rocker engine ran the first time I tried it. See here:http://www.homemodelenginemachinist.com/index.php?topic=14528.0
About a year ago I purchased a couple of material kits from The Little Machine Shop. Both are Stirling Engines. I must admit that when they arrived I was overwhelmed with the complexity of the machining needed to build them from the raw materials. They have been sitting on the shelf for some time. As a novice hobby machinist, my first build was a little rocker engine, and it ran the very first time I put air to it. That and all of your kind comments encouraged me to bring down one of the Stirling material kits from the shelf. After spending a lot of time going over the pages of prints and pictures, I decided to start the build. Having all the prints in Metric was my first challenge. I learned how to do the conversion to Imperial and that seemed to help a lot. In the mean time I ordered several measuring tools that are Metric as well.
The picture below shows some of the first pieces that I finished off. I first did the base plate on my home brew CNC. Using CamBam I drew and compiled the G-Code to face off the surface of the aluminum plate. After several passes, a thousands or two at a time, I think it came out really looking nice and it is smooth as a piece of glass! I really like the "tooling" finish my mill leave behind.
I then faced off the flywheel and drive pulley mounting block the same way, using the CNC to true up all the edges and surfaces. The drive shaft and bushings were next. Then the drive pulley and flywheel. One piece at a time I am turning chunks of aluminum into finished parts. This is a really neat hobby, and I am really learning a lot by trial and error as I move ahead.
Next I managed to get all the parts of the flywheel assembly to fit together and spin very smoothly in it's mount. I must admit that I had to make three drive shafts to get everything the right size to fit together. There must be a simple way of turning a piece of brass to "press fit size" the first time! It seems like every time I try I end up taking one last pass too many, the the fit is too loose. Oh well, hopefully my skills will improve with time.
Here is a picture of the drive shaft and wheels all together on the base plate. Along with it is the aluminum block that holds the hot and cold cylinders in place. I think that has really come out very nice as well. Again I love the machining finish left behind by the CNC. It is finished expect for drilling the air passage the long way thru the block holding the cylinders. Have a long drill coming, and that hole is my next challenge.
The next picture shows the two cylinders in place on their mounting block. I kind of feel like it is cheating a bit on the build, having the cylinders and pistons the only parts that came in the kit that were finished. As those are probably the most critical parts for the engine to work properly, I guess I am comfortable with this my first Stirling build, to not need to worry about building those individual parts.
The big round chunk of aluminum on the left is the finished cooling heat sink for the hot side of the engine. I used the CNC to bore the hole in the center and it is a beautiful fit to the hot cylinder. I pushed it on, left it on the bench over night, and the next day I could not remove it. I sat it on a window ledge in the sun and in about an hours time I was able to slide it back off the cylinder. Boy, to me that is a perfect fit. Guess I got really lucky on that one.
The next pictures shows some more progress. I cut the cooling fins into the cooling heat sink. I call it my "need to plan ahead" piece! As you can see, two of the fins are considerable thinner than the rest! Should have done a bit better on the planning, BEFORE I started turning the piece! Other than the looks, I guess it really will not matter when all is said and done.
In the foreground is the alcohol burner. Two more chunks of raw aluminum turned into a finished piece. One thing about all of this so far, I have put more time on my lathe with this project, than I have in the two years I have owned it. Hopefully my skills are improving with each piece I turn out!
The next picture shows the finished heat sink slipped on the hot cylinder. Let it set over night again, and it is firmly attached, all by itself! Looks like all I have left to do is build up the connecting rod assemblies, get all the parts assembled together, and then fire it up! At the rate I am going probably a couple of more weeks and I will see if it runs. Will add more pictures and comments as I progress.
