Nick, can't say at the moment, our flywheel is lying down with that side on the ground. Perhaps if it didn't weigh 6 tonnes we could have a quick peek. It will be moved soon though so I will try to remember to look.Ian, I do have a question re the flywheel.
........Are these teeth cast or machined?.......
TIA,
Nick
I found a bit of railing from the platform, sorry no casting here, the verticals are 25mm solid round while the horizontals are 20mm tubing. There is a little machined block to join each section.
The ladder also uses solid round uprights but the steps are cast. Here they are looking up from below.
Ian.
