I apologise to wheelwright for not acknowledging his post before, but I just had another look at the video, and you can plainly see the movement of the eccentrics for a similar fuel pump just above the governor housing.
Ian.
Ian.
but I can tell you now that that is the fuel pump for this engine.
or was that the original paint job?
Don't hold your breath if you mean the big engine. Yes it will run one day but that could be quite a few days/weeks/months/who knows? We still need to organise shed space and a massive concrete foundation for the engine and alternator which together weigh about 40-45 tonnes all up. Also a supply of starting air at about 600psi/40 atmospheres!....... Hope to see a video of it running one of these days.
Although it only starts on one cylinder and air is only admitted for a very short time.And that with about 80 l displacement per cylinder.
According to some original info, 520psi/35atm at idle, 920psi/63atm at full load. The engine driven compressor is rated at 1000psi/68atm. The blast pressure seems to have to be manually adjusted by the operator to suit the current engine operating conditions, but as those conditions were not likely to change from one moment to the next, it probably was not a great inconvenience.Do you know the pressure for the blast air? Should be something like 100 atm.
Nick
That piston is 850mm long
Yes it does, and it is, Nick. We have assembled the injectors, but I will see if one can be pulled down again as I don't have any pictures of the internals, although I believe you will not be attempting a working one! That spring basically bears on the end of the needle valve which extends all the way to the nozzle of the injector. The rocker lifts it at the same point. There are no other moving parts inside, only what is referred to as the 'atomiser', a collection of holes and channels designed to let the blast air cause as much turbulence to the fuel as possible when the needle valve opens. For what it is worth, a fully assembled injector is a two man lift!I guess, the spring for the injector assembly sits in the cylinder, ....... And it is an compression spring for obvious reasons.
