Some of you didn't understand the gnome monosoupape.
This engine has two valves per cylinder (if in doubt, read wikipedia first before answering).
1)the namegiving monosoupape, located at the top of the cylinder and controlled by a cam. Which is an poppetvalve type outlet.
2)the intakevalve, which is basically a hole located in the piston and opened by the suction caused by the piston on downward travel during induction stroke.
Rich mixture with lots of oil is sucked from the crankcase into the cylinder until the vaccum in the cylinder ceases and counterweights close the intakevalve.
As you can see, poweroutput is strongly limited by bad cylinder filling at high rpm, as the induction controlled valve will not open nor close at the right time.
