arborpress
Active Member
- Feb 27, 2013
- 30
- 1
Yes, I've been on his site quite a bit. All of his modifications are very interesting. That's where I got the idea of using a treadmill motor
There is nothing about the TAIG's design that would imply that.Perhaps someone else can answer, please.
I got a story that the Taig was actually an actuator of sorts from some aircraft which someone had re-developed. I'm not bothered one way or another but it made me think.
These days it makes more sense to consider electronic alternatives for feed and screw cutting.Today, I'd settle for a lathe with screwcutting abilities if I was wanting to do any boring of model engine cylinders. If you look at some of the other postings here, you will find that there are some very funny questions about reaming and boring that need not have arisen.
These are certainly acceptable as long as your goals aren't precision machining on very small parts. One of the reasons I see the various Mini lathes as a good long term investment is their utility to make those very small parts. Even if your model engineering interests tend to larger devices, requiring a larger lathe, the mini lathes can still be useful for making smaller parts.I apologise for accidentally running over some sacred cows but I'd be heading for a cheap( ish) and nasty-ish Chinese lathe which comes with both chucks and a faceplate and the ability to take a set of cheap-ish collets and screwcuts and has fine feeds under power in both imperial and metric dimensions.
Huh? Every lathe requires some self built tooling to be useful. Half the effort in building up a shop involves equipping your machinery with the accessories to make it useful.Not perfect or anywhere near perfect but adequate to make more of its own tooling and goodies without having a coronary or nervous breakdown for the user.
I was going to list what eventually ended up on my old battered mangle of a Myford-- and became a little embarrassed.
Go for a 918 or something similar.
I stumbled upon Clisby Mini machines today. has anybody ever heard of them? Apparently they were in production in the 70s and have resumed production. very cheap, even cheaper than the taig. I believe they are australian. http://www.precisiontools.com.sg/CLISBYMINILATHES.htm
Supposedly, this Clisby fellow is the guy who designed the sherline.
There is definitely more than a little truth to that - http://www.sherline.com/sherhist.htmSupposedly, this Clisby fellow is the guy who designed the sherline.
