What all is required to get into this hobby?
What about the actual cutting tools?
This is one area where reading learning and applying the knowledge will save you money.
Download and print this PDF
http://www.littlemachineshop.com/instructions/GrindingToolBits.pdf
Buy a handful of these 10 or a dozen Or if you want get 20 and you get a couple for free. And you can grind both ends. so 20 will last a while and give 40 cutting edges. 20 cutters wil cost under $40. Enco often has free shipping codes.
interstate 5/16 M-2 tool blank
The down side is you need a bench grinder or belt sander.
A new good " bench grinder is about $ 100 IMHO dewalt is a good brand.
The up side of buying a handful of HSS bits nd a grinder is the grinder should last a lifetime and a couple few handfuls of bits will last a very long time . the next handful you buy can be 5% cobalt they wear better for harder materials.
You may be able to find a good used one.
you will need a boring bar or set and a parting tool and holder. but you can even grind parting tools and small boring bars from these blanks.
Hope this helps.
The below attachment gives a chart of lathe tools.
Oooh. Nice! Gives me a reason to replace the cord on the century-old bench grinder that's collecting dust and dirt daubers in my carport. Thing still turns smooth as butter despite age and disuse, a new cord and a thorough cleaning/lubing and itt'l be good as new.
You have a grinder GOOD looks like you now have a place to start and only have to spend a few dollars
