If you have anything that can work to 5 decimal places, go for it. As a general rule, numbers used in mechanical drawings are rounded off to three decimal places, or even two, depending on the degree of accuracy required. Only very critical fits may be given a fourth decimal place, because most shops don't have machines that will work to such close tolerances. When you get the crankshaft set to 15 degrees, (before the piston reaches bottom dead center) the cam should be positioned so that the rocker arm is just touching the valve, but not lifting it yet.
