The rewind spring from a chainsaw, lawnmower or weed-eater all are close to the right size and work very well.---BrianCan anyone give me some ideas where to start looking for the spring steel for the rocker arm?
it is my understanding that honing is done for engines with rings in order to do 2 things, 1 is oil control and the other is to make the ring rotate or spin.
the scratches help hold oil on the walls of the cylinder and the cross hatch pattern I have been told (others more learned than I should correct me here) will cause the ring to spin on the piston as well.
lapping is for example a 2 stroke engine that has no rings. like the rc aircraft engine I am working on so the cylinder is slick and smooth because there is no ring and the piston must fit almost perfect to the cylinder.
edit - I know the Webster plans call for rings so I would say you should hone it. if you are subbing an oring for rings then I would not do a course hone job because it might wear out the rubber ring quicker.
John.
I have Vitonrings on my Webster and on my Hoglet. I have lapped cyl.on both. They'r runnig great, and have no lack of compression after many houers.
Btw. I just come in from my shop after running them. Usualy start's on first flick;D
Best reg
CS
Simister--Just go ahead and use a viton ring with the bore the way it is now. After half an hour the o-ring will be worn out, but the bore will be polished smooth. Then pull the piston and change the o-ring for a new one.---Brian
