simister
This is the cylinder head frame that I worked on today. All I need to do is tap the thread for the NGK spark plug and bore the recess for it. I won't do that until I receive the plug so I can double check the dimensions and thread.
I have ordered some drill rod for the cam shaft. I am also going down to the Viton Dealer tomorrow and pick up a few Viton O-rings.
You will notice on the photo that one of the holes is slightly damaged at the start of the hole (this was the last hole to drill). I was being very careful, however, I had inadvertently knocked the adjustment wheel on the milling machine table. To make sure that it was going to be in the correct position in relation to the other holes, I reversed the piece and drilled it from the other side. This took me about 45 minutes to set up so that it was going to be in the right position. Anyway, all worked out ok.
![IMG_20150126_154324584.jpg IMG_20150126_154324584.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/30/30208-IMG-20150126-154324584.jpg)
![IMG_20150126_154309355.jpg IMG_20150126_154309355.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/30/30209-IMG-20150126-154309355.jpg)
