xander janssen
- Jan 5, 2012
- 174
- 210
Hi all,
I have a question regarding a wasted spark scheme i.e. two spark plugs firing at the same time in a two cylinder engine.
In the book of Doug Kelley, there is the Titan, a 2 cylinder 360 degree engine. Here I understand the wasted spark idea: one plug fires at the end of the compression stroke, while the wasted fires at the same time, which is at the end of the exhaust stroke. This is exactly how Wikipedia explains it.
However, in the same book there is the Nash engine, which is a 180 degree configuration. This is also stated to be a wastes-spark design. Here I do not understand the wasted park idea. As the second cylinder is fired at the end of the compression stroke, the wasted spark is fired in the first cylinder at the end of the intake stroke. Wouldn't this cause ignition of the mixture? I can imagine that the mixture, although not yet compressed, is still able to burn. Or is it just not burning as it is not yet compressed causing no flame propagation.
Or does it sometimes fire the uncompressed cylinder and by that have no mixture for the following power stroke? This could explain the irregular sound that all the Nash engines in YouTube produce?
Xander
Xander
